Zum Hauptinhalt wechseln
Motorola Moto E4 Motherboard Cover Replacement
Was du brauchst
  1. Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: Schritt 1, Bild 1 von 2 Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: Schritt 1, Bild 2 von 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: Schritt 2, Bild 1 von 2 Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: Schritt 2, Bild 2 von 2
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Motherboard Cover Replacement: Schritt 3, Bild 1 von 2 Motorola Moto E4 Motherboard Cover Replacement: Schritt 3, Bild 2 von 2
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Nate Tjepkema
1.236 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S2-G4, White Winter 2019 Mitglied von Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 587
