Zum Hauptinhalt wechseln
Motorola Moto E4 Rear Facing Camera Replacement
Was du brauchst
  1. Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: Schritt 1, Bild 1 von 2 Motorola Moto E4 Rear Facing Camera Replacement, Remove the rear cover: Schritt 1, Bild 2 von 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: Schritt 2, Bild 1 von 2 Motorola Moto E4 Rear Facing Camera Replacement, Remove the motherboard cover: Schritt 2, Bild 2 von 2
    • The battery is shown inserted in the Moto E4, but it should be removed before performing the following step.
    • Remove all nine 4 mm Phillips screws from the top plastic cover.
  3. Motorola Moto E4 Rear Facing Camera Replacement: Schritt 3, Bild 1 von 2 Motorola Moto E4 Rear Facing Camera Replacement: Schritt 3, Bild 2 von 2
    • Gently pry up the plastic cover using a plastic opening tool.
    • Start by inserting the tool under the cover's right edge, as indicated by the first picture.
    • Pry up, and continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Rear Facing Camera Replacement: Schritt 4, Bild 1 von 3 Motorola Moto E4 Rear Facing Camera Replacement: Schritt 4, Bild 2 von 3 Motorola Moto E4 Rear Facing Camera Replacement: Schritt 4, Bild 3 von 3
    • This step can be skipped if you are only removing the front-facing camera. For all other repairs, continue as follows.
    • Disconnect the rear-facing camera by prying straight up on the connector on its right side.
    • Remove the rear-facing camera from the Moto E4.
Abschluss
Nate Tjepkema
1.254 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S2-G4, White Winter 2019 Mitglied von Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 21
Insgesamt: 769
