Zum Hauptinhalt wechseln
Motorola Moto E4 Vibrator Replacement
Was du brauchst
  1. Motorola Moto E4 Vibrator Replacement, Remove the rear cover: Schritt 1, Bild 1 von 2 Motorola Moto E4 Vibrator Replacement, Remove the rear cover: Schritt 1, Bild 2 von 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Vibrator Replacement, Charging Port: Schritt 2, Bild 1 von 1
    • Remove the six 4mm screws from the bottom plastic cover with a Phillips driver bit.
  3. Motorola Moto E4 Vibrator Replacement: Schritt 3, Bild 1 von 1
    • Gently pry the plastic cover from the phone using an iFixit opening tool.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Vibrator Replacement: Schritt 4, Bild 1 von 3 Motorola Moto E4 Vibrator Replacement: Schritt 4, Bild 2 von 3 Motorola Moto E4 Vibrator Replacement: Schritt 4, Bild 3 von 3
    • Detach the two ribbon cable connectors from the top of the board using an iFixit opening tool.
    • Unplug the antenna cable connector from the board using an iFixit opening tool.
  5. Motorola Moto E4 Vibrator Replacement: Schritt 5, Bild 1 von 3 Motorola Moto E4 Vibrator Replacement: Schritt 5, Bild 2 von 3 Motorola Moto E4 Vibrator Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Halberd Spudger
    $2.99
  6. Motorola Moto E4 Vibrator Replacement: Schritt 6, Bild 1 von 2 Motorola Moto E4 Vibrator Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 4mm silver screws holding down the charging port board with Phillips bit.
  7. Motorola Moto E4 Vibrator Replacement: Schritt 7, Bild 1 von 2 Motorola Moto E4 Vibrator Replacement: Schritt 7, Bild 2 von 2
    • Place the iFixit opening tool underneath the board in between the micro USB port and the microphone.
    • Push forward and lift gently until the board lifts up.
    • Remove the charging port board from the device.
  8. Motorola Moto E4 Vibrator Replacement, Vibrator: Schritt 8, Bild 1 von 2 Motorola Moto E4 Vibrator Replacement, Vibrator: Schritt 8, Bild 2 von 2
    • Gently pull the vibrator upwards to remove the vibrator wires from the silver clasp holding the wires to the board.
    • Pull directly upwards to remove the vibrator from its connector.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Nate Tjepkema
1.254 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S2-G4, White Winter 2019 Mitglied von Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 17
Letzte 30 Tage: 20
Insgesamt: 600
