Zum Hauptinhalt wechseln
Motorola Moto E6 Charging Dock Replacement
Was du brauchst
  1. Motorola Moto E6 Charging Dock Replacement, Back Cover: Schritt 1, Bild 1 von 2 Motorola Moto E6 Charging Dock Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Charging Dock Replacement, Battery: Schritt 2, Bild 1 von 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Charging Dock Replacement, Charging Dock: Schritt 3, Bild 1 von 1
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Charging Dock Replacement: Schritt 4, Bild 1 von 1
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Charging Dock Replacement: Schritt 5, Bild 1 von 1
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Charging Dock Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S2-G3, White Winter 2020 Mitglied von Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 26
Insgesamt: 2,896
