Zum Hauptinhalt wechseln
Motorola Moto E6 Haptic Feedback Motor Replacement
Was du brauchst
  1. Motorola Moto E6 Haptic Feedback Motor Replacement, Back Cover: Schritt 1, Bild 1 von 2 Motorola Moto E6 Haptic Feedback Motor Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Haptic Feedback Motor Replacement, Battery: Schritt 2, Bild 1 von 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Haptic Feedback Motor Replacement, Charging Dock: Schritt 3, Bild 1 von 1
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Haptic Feedback Motor Replacement: Schritt 4, Bild 1 von 1
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Haptic Feedback Motor Replacement: Schritt 5, Bild 1 von 1
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Haptic Feedback Motor Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
  7. Motorola Moto E6 Haptic Feedback Motor Replacement, Haptic Feedback Motor: Schritt 7, Bild 1 von 3 Motorola Moto E6 Haptic Feedback Motor Replacement, Haptic Feedback Motor: Schritt 7, Bild 2 von 3 Motorola Moto E6 Haptic Feedback Motor Replacement, Haptic Feedback Motor: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, gently lift the haptic feedback motor out of its position in the bottom left corner of the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 400
