Zum Hauptinhalt wechseln
Motorola Moto E6 Rear Facing Camera Replacement
Was du brauchst
  1. Motorola Moto E6 Rear Facing Camera Replacement, Back Cover: Schritt 1, Bild 1 von 2 Motorola Moto E6 Rear Facing Camera Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Rear Facing Camera Replacement, Battery: Schritt 2, Bild 1 von 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Rear Facing Camera Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Rear Facing Camera Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Rear Facing Camera Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 1.1 mm T4 Torx screws from the bottom left and top right sides of the motherboard.
  6. Motorola Moto E6 Rear Facing Camera Replacement: Schritt 6, Bild 1 von 1
    • Remove the two press fit cables at the bottom of the motherboard with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
    • After removing the cables, remove the motherboard from the phone by hand.
  7. Motorola Moto E6 Rear Facing Camera Replacement, Rear Facing Camera: Schritt 7, Bild 1 von 1
    • Remove the press fit cable using the plastic opening tool, and remove the camera from the phone.
Abschluss
Cal Poly, Team S2-G3, White Winter 2020 Mitglied von Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 602
