Einleitung
The camera on the Motorola Moto E6 should be replaced if it is taking blurry pictures, the lens is scratched, or the lens is cut. Use this guide to replace the camera module on the Moto E6. The motherboard has to be taken out first because there are cables from the camera on the back of the motherboard.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Begin by prying open the bottom right of the device using the plastic opening tool.
Work your way around the edge of the device, slowly prying open the casing until it pops off.
Use the opening tool on the divot located below the battery to pop it out.
Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
Use the plastic opening tools to pry open the piece located at the top of the device.
Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
Pop off the piece above the battery compartment.
Remove the two 1.1 mm T4 Torx screws from the bottom left and top right sides of the motherboard.
Remove the two press fit cables at the bottom of the motherboard with the plastic opening tool.
Remove the coaxial cable using the plastic opening tool.
After removing the cables, remove the motherboard from the phone by hand.
Remove the press fit cable using the plastic opening tool, and remove the camera from the phone.
