Zum Hauptinhalt wechseln
Motorola Moto E6 Screen Assembly Replacement
Was du brauchst
  1. Motorola Moto E6 Screen Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 2 Motorola Moto E6 Screen Assembly Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Screen Assembly Replacement, Battery: Schritt 2, Bild 1 von 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Screen Assembly Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Screen Assembly Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Screen Assembly Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 1.1 mm T4 Torx screws from the bottom left and top right sides of the motherboard.
  6. Motorola Moto E6 Screen Assembly Replacement: Schritt 6, Bild 1 von 1
    • Remove the two press fit cables at the bottom of the motherboard with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
    • After removing the cables, remove the motherboard from the phone by hand.
  7. Motorola Moto E6 Screen Assembly Replacement, Charging Dock: Schritt 7, Bild 1 von 1
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  8. Motorola Moto E6 Screen Assembly Replacement: Schritt 8, Bild 1 von 1
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  9. Motorola Moto E6 Screen Assembly Replacement: Schritt 9, Bild 1 von 1
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
  10. Motorola Moto E6 Screen Assembly Replacement: Schritt 10, Bild 1 von 1
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
  11. Motorola Moto E6 Screen Assembly Replacement, Screen Assembly: Schritt 11, Bild 1 von 2 Motorola Moto E6 Screen Assembly Replacement, Screen Assembly: Schritt 11, Bild 2 von 2
    • After removing the motherboard and the charging dock, the screen assembly can be replaced.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Pro Tip.
The OEM parts for this do not include the flex that connects the Sub to main PBA, nor the earspeaker, nor the buttons or Vibration motor, so all of those will need to be moved over if you are utilizing OEM original components.
Aksel Barnes - Antwort
you get me right to the point where i can get to the screen. now, how i do iget it off? put the new one on???
Bobby Browning - Antwort
Use heat on the display to loosen the adhesive. Then you can separate the display and put in the new one.
Thaddeus Ervin -
Sorry, these instructions are far from complete.
Jon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 37
Insgesamt: 3,232
