Zum Hauptinhalt wechseln
Motorola Moto E6 Speaker Replacement
Was du brauchst
  1. Motorola Moto E6 Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 2 Motorola Moto E6 Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Speaker Replacement, Battery: Schritt 2, Bild 1 von 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Speaker Replacement, Speaker: Schritt 3, Bild 1 von 1
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Speaker Replacement: Schritt 5, Bild 1 von 3 Motorola Moto E6 Speaker Replacement: Schritt 5, Bild 2 von 3 Motorola Moto E6 Speaker Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, lift the speaker from the motherboard located at the top of the device.
    • When replacing with a new component, make sure the clips are facing towards the user.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 1,180
