Einleitung
The speaker in the Motorola Moto E6 can be replaced by following this guide. The speaker should be replaced if it is visually damaged or if it fails to produce sound. The speaker should also be replaced if the user notices a lack of volume or pitch of the sound coming from the speaker.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Begin by prying open the bottom right of the device using the plastic opening tool.
Work your way around the edge of the device, slowly prying open the casing until it pops off.
Use the opening tool on the divot located below the battery to pop it out.
Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
Use the plastic opening tools to pry open the piece located at the top of the device.
Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
Pop off the piece above the battery compartment.
Using tweezers, lift the speaker from the motherboard located at the top of the device.
2 weitere Personen haben diese Anleitung absolviert.
