Einleitung
This guide shows you how to replace the speaker on a Motorola Moto G 1st Generation smartphone.
Was du brauchst
Schritt 1 Rear Panel
Achtung: Die Schritte 1-3 stammen von einer Anleitung, die derzeit bearbeitet wird.
Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
Use a plastic opening tool to remove the protective cover.
Use the plastic opening tool to remove the Speaker from the protective cover.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
