Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will teach you how to replace the motherboard in your Moto G, in the event that it is malfunctioning. It may take a while, since the battery and SD/SIM card reader must be removed first, but all you will need are a T5 Torx screwdriver and a plastic opening tool.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure your Moto G is turned off and that any SIM or SD cards are removed before beginning disassembly. Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger. Work your way down the sides to avoid cracking the rear cover.
    • Make sure your Moto G is turned off and that any SIM or SD cards are removed before beginning disassembly.
    • Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
    • Work your way down the sides to avoid cracking the rear cover.
  2. Remove the eight 4.2 mm screws at the top and bottom of the phone using a T5 Torx screwdriver. Using the same screwdriver, remove the six 3.2 mm screws on the sides. Remove the next layer of the phone by prying it off with your fingers.
    • Remove the eight 4.2 mm screws at the top and bottom of the phone using a T5 Torx screwdriver.
    • Using the same screwdriver, remove the six 3.2 mm screws on the sides.
    • Remove the next layer of the phone by prying it off with your fingers.
  3. Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone. Disconnect the battery connector by prying it off of the motherboard. Disconnect the vibration motor by prying its connector off of the motherboard.
    • Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone.
    • Disconnect the battery connector by prying it off of the motherboard.
    • Disconnect the vibration motor by prying its connector off of the motherboard.
  4. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  5. Using a plastic opening tool, carefully pry off the entire SIM/SD card reader component. Don't worry about ripping the copper foil a little bit, it is easy to put back on. When reassembling the device, do not attempt to smooth the foil down with your finger. Metal foil can become sharp if folded in a certain way, and you may be cut.
    • Using a plastic opening tool, carefully pry off the entire SIM/SD card reader component.
    • Don't worry about ripping the copper foil a little bit, it is easy to put back on.
    • When reassembling the device, do not attempt to smooth the foil down with your finger. Metal foil can become sharp if folded in a certain way, and you may be cut.
    • The battery may be removed without removing the SIM/SD card reader. Simply peel back the copper foil from the opposite end of the device, stopping just before you reach the SIM/SD card reader.
  6. Peel off the two black stickers on the right side of the battery using your fingers. Remove the battery by pulling the right side of it upwards. The black stickers are the protruding ends of the two parallel adhesive strips which hold the battery in place. You can see the adhesive strips in the third image. Focus your effort on these regions.
    • Peel off the two black stickers on the right side of the battery using your fingers.
    • Remove the battery by pulling the right side of it upwards.
    • The black stickers are the protruding ends of the two parallel adhesive strips which hold the battery in place. You can see the adhesive strips in the third image. Focus your effort on these regions.
    • If you did not remove the SIM/SD card reader in the previous step, you will need to carefully slide the battery ribbon cable out from under it once you have freed the battery from the adhesive strips.
  7. Remove LCD connector by lifting the black plastic flap. Remove LCD connector by lifting the black plastic flap. Remove LCD connector by lifting the black plastic flap.
    • Remove LCD connector by lifting the black plastic flap.
  8. Using a T5 Torx screwdriver, unscrew the three 2.2 mm screws holding the motherboard in place. Using a T5 Torx screwdriver, unscrew the three 2.2 mm screws holding the motherboard in place. Using a T5 Torx screwdriver, unscrew the three 2.2 mm screws holding the motherboard in place.
    • Using a T5 Torx screwdriver, unscrew the three 2.2 mm screws holding the motherboard in place.
  9. Carefully remove the motherboard. Carefully remove the motherboard.
    • Carefully remove the motherboard.
Abschluss
29 weitere Nutzer haben diese Anleitung absolviert.
Jared Geraets
637 Reputation
1 Anleitung geschrieben
Cal Poly, Team 1-19, Maness Fall 2015 Mitglied von Cal Poly, Team 1-19, Maness Fall 2015
CPSU-MANESS-F15S1G19
4 Mitglieder
10 Anleitungen geschrieben
What about Android, it comes already flashed on a new motherboard or I need to flash it myself?
marcelmaximo - Antwort
Where can i buy mother board for moto g 2nd gen lte. Any idea?
kasi balaji - Antwort
Please give me moto g2 motherboard
Kvasu - Antwort
hi ...great guide thanks...Ihave a question Can a Motherboard from a Motorola Moto G2 XT1068 fit into a G2 XT1072 phone Thanks
Paul - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 6
Letzten 30 Tage: 54
Insgesamt: 16,472
