Einleitung
This guide will show you how to replace the SIM/SD card reader of your Motorola Moto G 3rd Generation. Replacing this part requires disassembling much of the phone.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
Evenly apply heat to the edges of the touchscreen to loosen the adhesive. Continue to Step 3 once the edge of the screen is warm to the touch.
As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick. A suction cup may also be useful here.
Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary.
In diesem Schritt verwendetes Werkzeug:Tesa 61395 Tape$5.99
Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
Pull the display cable from its socket on the motherboard.
Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
If adhesive residue is holding the motherboard in place, use a Jimmy to cut the adhesive between the motherboard and the back of the phone.
Carefully lift the right edge of the motherboard from the phone.
Use a plastic opening tool to disconnect the battery wires from the motherboard.
Remove the three 2.4 mm T4 screws from the right side and bottom of the SIM/SD card panel.
25 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
I replace with new SIM card reader gotten from China, but not working.
bhai china ka mal to aisa hi milega
Any further solution to this.
Ha abhi le ke aata hu
