Einleitung
Click here for an updated version of this guide. The version you are viewing is retained for historical purposes.
In this guide we will be removing and replacing the motherboard, which is the main source for all the other guides.
Was du brauchst
Use the plastic opening tool to open the back cover as shown in the photo.
Heat an iOpener in the microwave for 30 seconds.
Place the heated iOpener on all four edges of the screen for approximately 2 minutes.
Apply the plastic opening tool on the edge of the screen near the front camera.
After creating enough space, allow the opening tool to be inserted on the side of the phone.
Create another space on the other side of the screen.
Leave the opening tool inserted.
Carefully apply the larger plastic opening tool by sliding it through the longer edge of the screen.
With a T4 screwdriver, remove the10 "yellow" 2mm screws and 4 "black" 2mm screws.
Use the metal spudger and lift the back cover on the bottom side of the phone (this is attached to the motherboard).
Remove the motherboard from the device.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
i broke my battery connectig port where we plug in the battery. What should i do?
PLZ answer
