Zum Hauptinhalt wechseln
Motorola Moto G4 Play Midframe Replacement
Was du brauchst
  1. Motorola Moto G4 Play Midframe Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola Moto G4 Play Midframe Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola Moto G4 Play Midframe Replacement, Battery: Schritt 1, Bild 3 von 3
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
  2. Motorola Moto G4 Play Midframe Replacement: Schritt 2, Bild 1 von 3 Motorola Moto G4 Play Midframe Replacement: Schritt 2, Bild 2 von 3 Motorola Moto G4 Play Midframe Replacement: Schritt 2, Bild 3 von 3
    • Lift the case by the nearest corner to the divot and remove it from the phone.
  3. Motorola Moto G4 Play Midframe Replacement: Schritt 3, Bild 1 von 3 Motorola Moto G4 Play Midframe Replacement: Schritt 3, Bild 2 von 3 Motorola Moto G4 Play Midframe Replacement: Schritt 3, Bild 3 von 3
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
  4. Motorola Moto G4 Play Midframe Replacement, Midframe: Schritt 4, Bild 1 von 3 Motorola Moto G4 Play Midframe Replacement, Midframe: Schritt 4, Bild 2 von 3 Motorola Moto G4 Play Midframe Replacement, Midframe: Schritt 4, Bild 3 von 3
    • Remove any SIM card and/or memory card present using your hand.
  5. Motorola Moto G4 Play Midframe Replacement: Schritt 5, Bild 1 von 2 Motorola Moto G4 Play Midframe Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the small silicon cover at the bottom right of the camera using tweezers.
  6. Motorola Moto G4 Play Midframe Replacement: Schritt 6, Bild 1 von 1
    • Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
    • Some phones have two shorter screws, one on each side of the battery (double marked with orange circles at left). If your device has these shorter screws, make sure they go back in their original holes.
  7. Motorola Moto G4 Play Midframe Replacement: Schritt 7, Bild 1 von 3 Motorola Moto G4 Play Midframe Replacement: Schritt 7, Bild 2 von 3 Motorola Moto G4 Play Midframe Replacement: Schritt 7, Bild 3 von 3
    • Remove the back panel assembly with your hands.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Paola Rossi
502 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S17-G4, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G4, Boczar Spring 2018
USFT-BOCZAR-S18S17G4
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 1,443
