Einleitung
Use this guide to replace the rear camera of your Motorola Moto G4 Play when it brakes or it doesn't take clear photos.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
Remove battery from your phone.
Remove the small silicon cover at the bottom right of the camera using tweezers.
Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the mother board.
After detaching the connector, carefully remove the camera using tweezers. If you don't have tweezers, use your hands.
