Zum Hauptinhalt wechseln
Motorola Moto G4 Play Screen Replacement
Was du brauchst
  1. Motorola Moto G4 Play Screen Replacement, Remove back plate: Schritt 1, Bild 1 von 1
    • Remove back plate starting with this tab
  2. Motorola Moto G4 Play Screen Replacement: Schritt 2, Bild 1 von 1
    • remove battery
    • remove SD card and sim card
  3. Motorola Moto G4 Play Screen Replacement, remove screws and inner back plate: Schritt 3, Bild 1 von 2 Motorola Moto G4 Play Screen Replacement, remove screws and inner back plate: Schritt 3, Bild 2 von 2
    • remove 16 phillips 00 screws
    • the two screws on either side of the battery (red color on thread) are shorter than the other screws (blue color on thread)
    • don't forget this one hiding underneath this sticker
    • no screw here
    • remove the inner back plate
  4. Motorola Moto G4 Play Screen Replacement, Remove the motherboard: Schritt 4, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement, Remove the motherboard: Schritt 4, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement, Remove the motherboard: Schritt 4, Bild 3 von 3
    • disconnect antenna cable from motherboard with a spudger.
    • disconnect screen and digitiser cables with a spudger.
    • remove rear facing camera with a spudger
    • remove phillips 00 screw
    • Remove motherboard. this cable is still connected, you must disconnect it as you remove the motherboard.
    • There is a cable attached to the bottom of the motherboard, be careful when removing it
  5. Motorola Moto G4 Play Screen Replacement, Remove USB accessory board: Schritt 5, Bild 1 von 2 Motorola Moto G4 Play Screen Replacement, Remove USB accessory board: Schritt 5, Bild 2 von 2
    • disconnect antenna and data cable
    • remove philips 00 screws
    • Remove usb board and vibrator together.
    • vibrator is attached to usb board from the bottom, be careful and remove them together to prevent damage.
  6. Motorola Moto G4 Play Screen Replacement, Remove remaining components from screen assembly: Schritt 6, Bild 1 von 2 Motorola Moto G4 Play Screen Replacement, Remove remaining components from screen assembly: Schritt 6, Bild 2 von 2
    • Peel off black sticker under battery compartment.
    • peel off data cable
    • remove antenna wire
    • remove speaker
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Cottone Computing Mitglied von Cottone Computing
Business
1 Mitglied
2 Anleitungen geschrieben
3 Kommentare
what if the new screen does not turn on or light up when you turn the phone on??? what part is causing that issue??
lilmizzipf - Antwort
I’ve just wrapped up an abortive attempt to replace the screen on a friend’s G4 Play. It was aborted because the screen I bought off of ebay has only one digitizer connection on the upper left of the screen but my friend’s model has the two connections pictured in step 4 of this procedure. I can’t find an XT1601 screen on ebay or aliexpress or anywhere else that sports the twin connectors. What model of phone was this? Any clues on how to track this down?
jrhooker - Antwort
@jrhooker that’s the button cable
benjamin linne - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 24
Insgesamt: 5,699
