Zum Hauptinhalt wechseln
Motorola Moto G4 Play Screen Replacement
Was du brauchst
  1. Motorola Moto G4 Play Screen Replacement, Battery: Schritt 1, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement, Battery: Schritt 1, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
  2. Motorola Moto G4 Play Screen Replacement: Schritt 2, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 2, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 2, Bild 3 von 3
    • Lift the case by the nearest corner to the divot and remove it from the phone.
  3. Motorola Moto G4 Play Screen Replacement: Schritt 3, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 3, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 3, Bild 3 von 3
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
  4. Motorola Moto G4 Play Screen Replacement, Midframe: Schritt 4, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement, Midframe: Schritt 4, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement, Midframe: Schritt 4, Bild 3 von 3
    • Remove any SIM card and/or memory card present using your hand.
  5. Motorola Moto G4 Play Screen Replacement: Schritt 5, Bild 1 von 2 Motorola Moto G4 Play Screen Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the small silicon cover at the bottom right of the camera using tweezers.
  6. Motorola Moto G4 Play Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
    • Some phones have two shorter screws, one on each side of the battery (double marked with orange circles at left). If your device has these shorter screws, make sure they go back in their original holes.
  7. Motorola Moto G4 Play Screen Replacement: Schritt 7, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 7, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 7, Bild 3 von 3
    • Remove the back panel assembly with your hands.
  8. Motorola Moto G4 Play Screen Replacement, Rear Camera: Schritt 8, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement, Rear Camera: Schritt 8, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement, Rear Camera: Schritt 8, Bild 3 von 3
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the mother board.
  9. Motorola Moto G4 Play Screen Replacement: Schritt 9, Bild 1 von 1
    • After detaching the connector, carefully remove the camera using tweezers. If you don't have tweezers, use your hands.
  10. Motorola Moto G4 Play Screen Replacement, Charging Port: Schritt 10, Bild 1 von 2 Motorola Moto G4 Play Screen Replacement, Charging Port: Schritt 10, Bild 2 von 2
    • Use tweezers to pop up the antenna wire.
  11. Motorola Moto G4 Play Screen Replacement: Schritt 11, Bild 1 von 2 Motorola Moto G4 Play Screen Replacement: Schritt 11, Bild 2 von 2
    • Use the flat end of a spudger to pry up on the connector at the bottom of the battery space.
  12. Motorola Moto G4 Play Screen Replacement: Schritt 12, Bild 1 von 1
    • Remove the two (2) 3mm Phillips PH000 screws securing the charging port.
  13. Motorola Moto G4 Play Screen Replacement: Schritt 13, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 13, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 13, Bild 3 von 3
    • Insert the tweezers under the vibrator and gently lift up the whole part.
  14. Motorola Moto G4 Play Screen Replacement: Schritt 14, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 14, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 14, Bild 3 von 3
    • Pop up on the vibrator's connector to separate it from the charging port.
  15. Motorola Moto G4 Play Screen Replacement, Screen: Schritt 15, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement, Screen: Schritt 15, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement, Screen: Schritt 15, Bild 3 von 3
    • Using an opening tool, pry up one of the connectors to the left of where the sim card was located.
  16. Motorola Moto G4 Play Screen Replacement: Schritt 16, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 16, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 16, Bild 3 von 3
    • Pry up the next connector located right on top of the previous one.
  17. Motorola Moto G4 Play Screen Replacement: Schritt 17, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 17, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 17, Bild 3 von 3
    • Using the Phillips screwdriver, remove the screw that's found next to the speaker on the top left of the phone.
  18. Motorola Moto G4 Play Screen Replacement: Schritt 18, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 18, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 18, Bild 3 von 3
    • Using the plastic opening tool, carefully pry up the motherboard.
  19. Motorola Moto G4 Play Screen Replacement: Schritt 19, Bild 1 von 2 Motorola Moto G4 Play Screen Replacement: Schritt 19, Bild 2 von 2
    • Pull up the cable that connects the motherboard and the charging port.
    • It's on the side that's closer to the motherboard, you might need to push the cable down first, and then pull it up.
  20. Motorola Moto G4 Play Screen Replacement: Schritt 20, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 20, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 20, Bild 3 von 3
    • Pry up the frontal speaker with a plastic opening tool.
  21. Motorola Moto G4 Play Screen Replacement: Schritt 21, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 21, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 21, Bild 3 von 3
    • Peel the black tape up with a plastic opening tool and or your fingers.
  22. Motorola Moto G4 Play Screen Replacement: Schritt 22, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 22, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 22, Bild 3 von 3
    • Peel the flexible black cable using a plastic opening tool and or your fingers.
  23. Motorola Moto G4 Play Screen Replacement: Schritt 23, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 23, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 23, Bild 3 von 3
    • Peel up the small tape that's connected to the screen with a plastic opening tool.
  24. Motorola Moto G4 Play Screen Replacement: Schritt 24, Bild 1 von 2 Motorola Moto G4 Play Screen Replacement: Schritt 24, Bild 2 von 2
    • Place an iOpener on the edges to soften the screen adhesive.
  25. Motorola Moto G4 Play Screen Replacement: Schritt 25, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 25, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 25, Bild 3 von 3
    Plastic Cards
    $2.99
    • Insert the Jimmy knife through the edge.
    • Place a plastic card so that the adhesive doesn't stick back again.
    • Go around the edges of the device with the Jimmy knife until all the adhesive has been removed.
  26. Motorola Moto G4 Play Screen Replacement: Schritt 26, Bild 1 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 26, Bild 2 von 3 Motorola Moto G4 Play Screen Replacement: Schritt 26, Bild 3 von 3
    • Pull up on the LCD screen with your hands and remove it.
Abschluss
10 weitere Personen haben diese Anleitung absolviert.
Yordan Gil
447 Reputation
1 Anleitung geschrieben
USF Tampa, Team S17-G4, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G4, Boczar Spring 2018
USFT-BOCZAR-S18S17G4
4 Mitglieder
11 Anleitungen geschrieben
4 Kommentare zur Anleitung
The phone I just tried to fix had two digitizer connectors just like the one in this procedure, but all the replacement parts I can find on ebay and aliexpress etc. which claim to be for XT1601 - XT1609 have just a single connector. Any thoughts about why that would be?
jrhooker - Antwort
The smaller one is from the power and Volume buttons and needs tobe transfered to the new display if you bought one with Frame (which makes it much easier)
Marko Käppler - Antwort
I had to figure out that out myself. Yes, you will need to transfer the connector from the old frame to the new frame. I should also add, the frame I got had no buttons, so I had to get them from the old phone.
Joshua Rieth -
Good guide though I could not see the purpose of removing items 20, 21 & 22
pauldmallett - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 39
Insgesamt: 5,171
