Einleitung
Follow this guide to remove and replace the USB board.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
remove 16 00 philips screws
pull up sticker with tweezers to reveal the last screw
no screw here
remove battery sd card, and sim card
disconnect antenna with spudger
disconnect data cable with spudger
Remove 2 00 philips screws
carefully remove USB board and vibrator together
disconnect vibrator from board with spudger.
Pull the rubber support gasket off of the old usb port.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
