Einleitung
Over time, the speaker on the Motorola Moto G4 can crackle or distort audio. This guide will show you how to replace the speaker.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
Gently twist or pry to open a small gap between the back cover and the body of the phone.
While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
Keep your tool inserted slightly under the back cover, and slide it around the top corner.
If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
Use a spudger to disconnect the camera flash connector by prying it straight up.
Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
Gently pry straight up to disconnect the battery.
Strong adhesive secures the earpiece speaker. If necessary, apply heat or a few drops of isopropyl alcohol to help weaken the adhesive and make it easier to remove.
Pry up the speaker with a pry tool or a pair of tweezers. Be careful not to damage any surrounding components.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
i have problem with speaker. no sound. tried direct connecting external speaker . still no sound. so seems like its not sending signal. i checked all the settings
You should have clearly told us not to use the tweezers in such a way as to touch the bottom side of that speaker box. I accidentally touched the other side with my tweezer while removing which caused a hole in the thin metal membrane. Now my speaker works but has an incredible amount of distortion. You MUST put a warning for these things. Now I have to buy a new speaker module.
The warning should have told us to touch only the plastic black parts with the pointy end of the tweezers
will use on my other phone, people can hear me, I can’t hear them after a drop. Now I know how to check the phone speaker. Thanks
Is it essential to disconnect the battery? Or is that more safety protocol?
