Zum Hauptinhalt wechseln
Motorola Moto G5 Front Camera Replacement
Was du brauchst
  1. Motorola Moto G5 Front Camera Replacement, Back Cover: Schritt 1, Bild 1 von 2 Motorola Moto G5 Front Camera Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Front Camera Replacement: Schritt 2, Bild 1 von 3 Motorola Moto G5 Front Camera Replacement: Schritt 2, Bild 2 von 3 Motorola Moto G5 Front Camera Replacement: Schritt 2, Bild 3 von 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Front Camera Replacement: Schritt 3, Bild 1 von 3 Motorola Moto G5 Front Camera Replacement: Schritt 3, Bild 2 von 3 Motorola Moto G5 Front Camera Replacement: Schritt 3, Bild 3 von 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Front Camera Replacement: Schritt 4, Bild 1 von 2 Motorola Moto G5 Front Camera Replacement: Schritt 4, Bild 2 von 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Front Camera Replacement, Battery: Schritt 5, Bild 1 von 2 Motorola Moto G5 Front Camera Replacement, Battery: Schritt 5, Bild 2 von 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Front Camera Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Front Camera Replacement, Rear Facing Camera: Schritt 7, Bild 1 von 2 Motorola Moto G5 Front Camera Replacement, Rear Facing Camera: Schritt 7, Bild 2 von 2
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Front Camera Replacement: Schritt 8, Bild 1 von 3 Motorola Moto G5 Front Camera Replacement: Schritt 8, Bild 2 von 3 Motorola Moto G5 Front Camera Replacement: Schritt 8, Bild 3 von 3
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Front Camera Replacement: Schritt 9, Bild 1 von 3 Motorola Moto G5 Front Camera Replacement: Schritt 9, Bild 2 von 3 Motorola Moto G5 Front Camera Replacement: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
  10. Motorola Moto G5 Front Camera Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
  11. Motorola Moto G5 Front Camera Replacement: Schritt 11, Bild 1 von 1
    • Lift the motherboard up from the top of the phone.
  12. Motorola Moto G5 Front Camera Replacement: Schritt 12, Bild 1 von 1
    • Unplug the back connector from the motherboard using tweezers.
  13. Motorola Moto G5 Front Camera Replacement, Front Camera: Schritt 13, Bild 1 von 2 Motorola Moto G5 Front Camera Replacement, Front Camera: Schritt 13, Bild 2 von 2
    • Grab the connector with the tweezers and gently unplug the front camera from the motherboard.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S2-G3, Livingston Winter 2018 Mitglied von Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 31
Insgesamt: 2,085
