Zum Hauptinhalt wechseln
Motorola Moto G5 Motherboard Replacement
Was du brauchst
    1. Motorola Moto G5 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 Motorola Moto G5 Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
      • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
      • Pry with your fingernail or twist the spudger to release the back cover from the phone.
      Frag FixBot
      Kommentar hinzufügen
    2. Motorola Moto G5 Motherboard Replacement: Schritt 2, Bild 1 von 3 Motorola Moto G5 Motherboard Replacement: Schritt 2, Bild 2 von 3 Motorola Moto G5 Motherboard Replacement: Schritt 2, Bild 3 von 3
      • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
      Frag FixBot
    3. Motorola Moto G5 Motherboard Replacement: Schritt 3, Bild 1 von 3 Motorola Moto G5 Motherboard Replacement: Schritt 3, Bild 2 von 3 Motorola Moto G5 Motherboard Replacement: Schritt 3, Bild 3 von 3
      • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
      Frag FixBot
    4. Motorola Moto G5 Motherboard Replacement: Schritt 4, Bild 1 von 2 Motorola Moto G5 Motherboard Replacement: Schritt 4, Bild 2 von 2
      • Lift the back cover and remove it from the phone.
      • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
      Frag FixBot
    1. Motorola Moto G5 Motherboard Replacement, Battery: Schritt 5, Bild 1 von 2 Motorola Moto G5 Motherboard Replacement, Battery: Schritt 5, Bild 2 von 2
      • Insert your fingernail or the flat end of the spudger into the notch below the battery.
      • Pry with your fingernail or spudger until you free the battery from its recess.
      Frag FixBot
    2. Motorola Moto G5 Motherboard Replacement: Schritt 6, Bild 1 von 1
      • Remove the battery.
      • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
      Frag FixBot
    1. Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: Schritt 7, Bild 1 von 2 Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: Schritt 7, Bild 2 von 2
      • Remove the eight (8) 4mm screws with a Phillips screwdriver.
      Frag FixBot
    2. Motorola Moto G5 Motherboard Replacement: Schritt 8, Bild 1 von 3 Motorola Moto G5 Motherboard Replacement: Schritt 8, Bild 2 von 3 Motorola Moto G5 Motherboard Replacement: Schritt 8, Bild 3 von 3
      • Pry the top motherboard cover off using a plastic opening tool.
      • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
      Frag FixBot
    3. Motorola Moto G5 Motherboard Replacement: Schritt 9, Bild 1 von 3 Motorola Moto G5 Motherboard Replacement: Schritt 9, Bild 2 von 3 Motorola Moto G5 Motherboard Replacement: Schritt 9, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
      Frag FixBot
    1. Motorola Moto G5 Motherboard Replacement, Motherboard: Schritt 10, Bild 1 von 1
      • Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
      Frag FixBot
    2. Motorola Moto G5 Motherboard Replacement: Schritt 11, Bild 1 von 1
      • Lift the motherboard up from the top of the phone.
      Frag FixBot
    3. Motorola Moto G5 Motherboard Replacement: Schritt 12, Bild 1 von 1
      • Unplug the back connector from the motherboard using tweezers.
      Frag FixBot
Abschluss
11 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S2-G3, Livingston Winter 2018 Mitglied von Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Mitglieder
60 Anleitungen geschrieben
2 Kommentare zur Anleitung
is a xt1670 logic board compatible with a xt1671 phone?
Jaime Oziel Moreno - Antwort Teilen
While disassembling I accidentally broke off one of the antenna "pins" (the one under the audio jack). I'll try to solder it on again, but in case I cannot, you think it will affect its proper operation too much? I cannot test it right now as I am waiting a replacement side buttons board.
karajay - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 53
Insgesamt: 7,607
