Einleitung
This guide will replace a faulty or broken rear facing camera.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
Pry with your fingernail or twist the spudger to release the back cover from the phone.
Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
Insert your fingernail or the flat end of the spudger into the notch below the battery.
Pry with your fingernail or spudger until you free the battery from its recess.
Remove the eight (8) 4mm screws with a Phillips screwdriver.
Disconnect the marked connector with a pair of tweezers and remove the camera piece.
3 weitere Personen haben diese Anleitung absolviert.
