Zum Hauptinhalt wechseln
Motorola Moto G5s Plus Battery Replacement
Was du brauchst
  1. Motorola Moto G5s Plus Battery Replacement, Display: Schritt 1, Bild 1 von 3 Motorola Moto G5s Plus Battery Replacement, Display: Schritt 1, Bild 2 von 3 Motorola Moto G5s Plus Battery Replacement, Display: Schritt 1, Bild 3 von 3
    • Power off the phone before you begin.
    • Bring the heat gun one to two inches from the edges of the display to melt the display adhesive.
    • Spend equal amounts of time applying heat around the entire edge of the phone.
  2. Motorola Moto G5s Plus Battery Replacement: Schritt 2, Bild 1 von 2 Motorola Moto G5s Plus Battery Replacement: Schritt 2, Bild 2 von 2
    • Attach the suction cup to the display slightly to the left of center.
    • Exert a moderate force to pull on the suction cup. The display will come loose.
  3. Motorola Moto G5s Plus Battery Replacement: Schritt 3, Bild 1 von 3 Motorola Moto G5s Plus Battery Replacement: Schritt 3, Bild 2 von 3 Motorola Moto G5s Plus Battery Replacement: Schritt 3, Bild 3 von 3
    • Insert the opening tool inside the loosened edge.
    • Gradually work the opening tool around the edge of the entire screen to cut through the adhesive.
    • Do not wedge the opening tool too far beneath the screen. Using too much force can result in torn connector cables.
  4. Motorola Moto G5s Plus Battery Replacement: Schritt 4, Bild 1 von 3 Motorola Moto G5s Plus Battery Replacement: Schritt 4, Bild 2 von 3 Motorola Moto G5s Plus Battery Replacement: Schritt 4, Bild 3 von 3
    • The display should now be entirely loose, attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device.
    • Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display.
    • If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
  5. Motorola Moto G5s Plus Battery Replacement: Schritt 5, Bild 1 von 2 Motorola Moto G5s Plus Battery Replacement: Schritt 5, Bild 2 von 2
    • The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen.
    • Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
  6. Motorola Moto G5s Plus Battery Replacement: Schritt 6, Bild 1 von 2 Motorola Moto G5s Plus Battery Replacement: Schritt 6, Bild 2 von 2
    • Grab the unscrewed metal plate with your blunt tweezers.
    • Slide the metal plate to the left and then out to remove it.
    • Removing the plate will expose the display assembly's connection to the phone's motherboard.
  7. Motorola Moto G5s Plus Battery Replacement: Schritt 7, Bild 1 von 2 Motorola Moto G5s Plus Battery Replacement: Schritt 7, Bild 2 von 2
    • Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool.
  8. Motorola Moto G5s Plus Battery Replacement: Schritt 8, Bild 1 von 2 Motorola Moto G5s Plus Battery Replacement: Schritt 8, Bild 2 von 2
    • Lift up the detached right connector from its housing using blunt tweezers.
    • The housing has light adhesive underneath it. Use a small amount of force to remove the connector from the housing.
  9. Motorola Moto G5s Plus Battery Replacement, Fingerprint Sensor: Schritt 9, Bild 1 von 1
    • Remove the nine black 5mm Torx-5 screws.
    • Remove the seven silver 5mm Torx-5 screws.
  10. Motorola Moto G5s Plus Battery Replacement: Schritt 10, Bild 1 von 2 Motorola Moto G5s Plus Battery Replacement: Schritt 10, Bild 2 von 2
    • Remove the metal cover by prying underneath it with the opening tool.
  11. Motorola Moto G5s Plus Battery Replacement: Schritt 11, Bild 1 von 3 Motorola Moto G5s Plus Battery Replacement: Schritt 11, Bild 2 von 3 Motorola Moto G5s Plus Battery Replacement: Schritt 11, Bild 3 von 3
    • Grab ahold of the fingerprint sensor and push it through the opening in the metal cover.
  12. Motorola Moto G5s Plus Battery Replacement: Schritt 12, Bild 1 von 2 Motorola Moto G5s Plus Battery Replacement: Schritt 12, Bild 2 von 2
    • Remove the fingerprint connector by gently prying underneath the connector with the opening tool.
  13. Motorola Moto G5s Plus Battery Replacement, Battery: Schritt 13, Bild 1 von 1
    • The battery is now fully exposed and ready to be removed.
  14. Motorola Moto G5s Plus Battery Replacement: Schritt 14, Bild 1 von 2 Motorola Moto G5s Plus Battery Replacement: Schritt 14, Bild 2 von 2
    • Use the opening tool to remove the two metal connectors located above the battery.
    • Apply a gentle upward pressure to loosen the metal plates.
  15. Motorola Moto G5s Plus Battery Replacement: Schritt 15, Bild 1 von 3 Motorola Moto G5s Plus Battery Replacement: Schritt 15, Bild 2 von 3 Motorola Moto G5s Plus Battery Replacement: Schritt 15, Bild 3 von 3
    • Using the spudger, cut downwards along the black tape on left side of the battery.
  16. Motorola Moto G5s Plus Battery Replacement: Schritt 16, Bild 1 von 1
    • Use the opening tool to disengage the black connector located above the battery.
  17. Motorola Moto G5s Plus Battery Replacement: Schritt 17, Bild 1 von 1
    • Heating up the battery excessively could cause the battery to ignite
    • Use the heat gun along the back of the phone to loosen the adhesive that holds the battery in place.
    • Spend equal intervals of time on each area applying heat.
  18. Motorola Moto G5s Plus Battery Replacement: Schritt 18, Bild 1 von 3 Motorola Moto G5s Plus Battery Replacement: Schritt 18, Bild 2 von 3 Motorola Moto G5s Plus Battery Replacement: Schritt 18, Bild 3 von 3
    • Insert the spudger underneath the right side of the battery.
    • Apply a moderate upward force along the length of battery, until the battery lifts out of place.
    • Remove the battery with your hand.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Kevin George
1.072 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S4-G5, White Fall 2018 Mitglied von Cal Poly, Team S4-G5, White Fall 2018
CPSU-WHITE-F18S4G5
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Hello,
I would like to chance the battery.
But for me it isn’t not clear how to glue the screen back again. I can not find any sealing at the market
Thanks
Jirik - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 17
Letzte 30 Tage: 97
Insgesamt: 12,546
