Einleitung
This is a fingerprint scanner replacement guide for the Motorola Moto G7 Play, specifically the XT1952-3 and XT1952-2. The fingerprint is an important feature for the device, as it helps provide extra security to keep files safe. If the device no longer unlocks when the sensor is touched, then it should be replaced.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
Remove the nine 3.2 mm screws from the motherboard cover with a Phillips #00 screwdriver.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Lift motherboard cover from the bottom.
Using the iFixit opening tool, carefully disconnect the ribbon cable connecting the fingerprint scanner to the motherboard.
Remove the fingerprint scanner from the device.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
