Einleitung
This motherboard replacement guide should be attempted if other parts of the device were replaced, but the problem persisted. The steps should be followed for the Motorola G7 Play, models XT1952-3 and XT1952-2. The motherboard powers the whole device and makes it function, so it’s a very important part that should be replaced if it is damaged.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
Lift motherboard cover off by the bottom.
Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
Remove the motherboard from the device.
2 weitere Personen haben diese Anleitung absolviert.
