Einleitung
This guide will show each detailed step to removing and replacing the speaker inside Motorola G7 Play, model number XT1952-3 or XT1952-2. The speaker is used for phone calls and playing sound on the phone. If the phone no longer plays audio correctly or doesn’t have any audio the speaker will need to be replace.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Was du brauchst
Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
Lift motherboard cover off by the bottom.
Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
Remove the motherboard from the device.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Hiji just jj
Nice guide to repair any mobile phone
