Einleitung
If the power or volume buttons for the Motorola Moto G7 Plus are not functioning properly - sticky, will not register on the phone - use this guide to replace the buttons.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
The power and volume buttons toggle the power and control the volume level on the phone respectively. Faulty volume and power buttons can lead to loss of control over the power and volume of the phone.
Was du brauchst
Insert an opening pick under the screen, starting at the top of the phone.
Work the pick along the edges of the phone while placing them in the corners.
After placing the picks along the edge of the screen, refer to step 2.
Loosen the adhesive by cutting along the sides of the phone with the Jimmy Knife and prop open the back.
The fingerprint sensor is now visible and can be replaced.
Remove the sensor cable with the metallic cover on top.
Use the pick to pry off the white plastic piece that holds the volume and power buttons in place.
Use the spudger to hook under the volume button to remove it.
Using the spudger, hook the top of the power button hooking to remove it.
Eine weitere Person hat diese Anleitung absolviert.
