Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The speaker in the Motorola Moto G7 is a basic bottom-ported speaker made by Dolby Audio. The speaker is used to transmit noise out of the phone without any external headphones or Bluetooth speaker used. A broken speaker may consist of poor audio quality or no audio at all with the volume turned on.
Before beginning, make sure the device is unplugged from any chargers or headphones. Before starting, grab suggested tools and a new speaker.
  1. Use the iFixit opening tools to gently wedge the front screen from the rest of the device. Try to focus on the corners to make it easier to insert and use the iFixit opening picks. It is also recommended to use the iOpener or a heat gun to weaken the adhesive that holds the edges of the screen down.
    • Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
    • Try to focus on the corners to make it easier to insert and use the iFixit opening picks.
    • It is also recommended to use the iOpener or a heat gun to weaken the adhesive that holds the edges of the screen down.
    • The screen is glass, so when using force to lift the screen, be cautious of cracked glass and stray shards of glass coming off.
  2. Excessive glass and adhesive around the edges should be removed with the spudger.
    • Excessive glass and adhesive around the edges should be removed with the spudger.
    • The glass is black and may blend in with edges of the device. Be cautious using bare hands when moving the device.
  3. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  4. Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery. Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
    • Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
  5. Use a spudger to gently take off the metal piece that was held down by the screws. A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band. A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
    • Use a spudger to gently take off the metal piece that was held down by the screws.
    • A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
  6. Remove three 3.7mm T3 Torx screws from the bottom of the phone. Use the spudger to gently lift the speaker out of the phone. Use the spudger to gently lift the speaker out of the phone.
    • Remove three 3.7mm T3 Torx screws from the bottom of the phone.
    • Use the spudger to gently lift the speaker out of the phone.
Abschluss
Peter Nelson
334 Reputation
3 Anleitungen geschrieben
Cal Poly, Team S19-G6, White Winter 2020 Mitglied von Cal Poly, Team S19-G6, White Winter 2020
CPSU-WHITE-W20S19G6
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 10
Letzten 30 Tage: 56
Insgesamt: 154
