Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
This guide will show you step-by-step how to replace the back casing.
  1. Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Use the T6 screwdriver to remove the four screws holding the casing together.
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful. Note: the phone should be face up and the plastic opening tool should be face downwards
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Gently lift and remove the back casing. Gently lift and remove the back casing.
    • Gently lift and remove the back casing.
Abschluss
Luis Herrera
52 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 16-33, Maness Winter 2010 Mitglied von Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 5,022
