Zum Hauptinhalt wechseln
Motorola Moto Q Camera Replacement
Was du brauchst
  1. Motorola Moto Q Camera Replacement, Back Casing: Schritt 1, Bild 1 von 1
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Camera Replacement: Schritt 2, Bild 1 von 1
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Camera Replacement: Schritt 3, Bild 1 von 2 Motorola Moto Q Camera Replacement: Schritt 3, Bild 2 von 2
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Camera Replacement: Schritt 4, Bild 1 von 2 Motorola Moto Q Camera Replacement: Schritt 4, Bild 2 von 2
    • Gently lift and remove the back casing.
  5. Motorola Moto Q Camera Replacement, Camera: Schritt 5, Bild 1 von 2 Motorola Moto Q Camera Replacement, Camera: Schritt 5, Bild 2 von 2
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  6. Motorola Moto Q Camera Replacement: Schritt 6, Bild 1 von 2 Motorola Moto Q Camera Replacement: Schritt 6, Bild 2 von 2
    • Using your fingers, remove the plastic piece that holds the camera in place.
  7. Motorola Moto Q Camera Replacement: Schritt 7, Bild 1 von 2 Motorola Moto Q Camera Replacement: Schritt 7, Bild 2 von 2
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  8. Motorola Moto Q Camera Replacement: Schritt 8, Bild 1 von 2 Motorola Moto Q Camera Replacement: Schritt 8, Bild 2 von 2
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Dave Uth
35 Reputation
1 Anleitung geschrieben
Cal Poly, Team 16-33, Maness Winter 2010 Mitglied von Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 1,943
