Zum Hauptinhalt wechseln
Motorola Moto X 2nd Generation Back Cover Replacement
Was du brauchst
Einführungsvideo
  1. Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 3 Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 3 Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove SIM card tray.
  2. Motorola Moto X 2nd Generation Back Cover Replacement: Schritt 2, Bild 1 von 3 Motorola Moto X 2nd Generation Back Cover Replacement: Schritt 2, Bild 2 von 3 Motorola Moto X 2nd Generation Back Cover Replacement: Schritt 2, Bild 3 von 3
    • Insert the eject pin into the hole in the SIM card tray port and push the back cover with effort to open a gap.
    • Place the guitar pick into the gap.
  3. Motorola Moto X 2nd Generation Back Cover Replacement: Schritt 3, Bild 1 von 2 Motorola Moto X 2nd Generation Back Cover Replacement: Schritt 3, Bild 2 von 2
    • Slide the guitar pick to cut the adhesive sticker under the back cover. It's a little strong.
    • At last, peel off the soft back cover.If you get the new back cover without the logo ring, you need to remove the logo ring from old back cover.
Abschluss
19 weitere Personen haben diese Anleitung absolviert.
Sophia
43.911 Reputation
62 Anleitungen geschrieben
3 Kommentare zur Anleitung
The guide was easy to follow. I managed to complete it successfully using the recommended tools.
Hassan Almarzooq - Antwort Teilen
It seems that material and time alters the ease with which it opens. My bamboo cover, which has been my precious back cover, was very hard to remove. Probably temperature has affected the glue, that glued it on even more. I needed a scalpel to give me leverage enough, since the eject pin wasn't strong enough to pry it open.
[deleted] - Antwort Teilen
What type of adhesive do you use to reseal the back cover?
sfcvickers - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 12
Letzte 30 Tage: 35
Insgesamt: 26,389
