Zum Hauptinhalt wechseln
  1. Remove SIM card tray. Remove SIM card tray. Remove SIM card tray.
    • Remove SIM card tray.
  2. Use the eject pin to open a gap and place a guitar pick into the gap. Use the eject pin to open a gap and place a guitar pick into the gap.
    • Use the eject pin to open a gap and place a guitar pick into the gap.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Slide the guitar pick to cut the adhesive sticker and peel off the soft back cover. Slide the guitar pick to cut the adhesive sticker and peel off the soft back cover.
    • Slide the guitar pick to cut the adhesive sticker and peel off the soft back cover.
  5. Twist off three screws, pry up the securing bracket and remove the logo finally. Twist off three screws, pry up the securing bracket and remove the logo finally. Twist off three screws, pry up the securing bracket and remove the logo finally.
    • Twist off three screws, pry up the securing bracket and remove the logo finally.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Sophia
42.216 Reputation
62 Anleitungen geschrieben
So apparently, this phone was supposed to have a fingerprint scanner. To anyone who has done this repair, I'm sure you're as confused as me as to why there is a flex cable leading to the "M" logo with nothing attached. My though is that's where the scanner was going to go, and it just never happened, which also explains why the iconic Motorola M dimple is a separate part, compared to the old Moto X and the Gs and Es, which was part of the back plastic cover.
Jeff Caauwe - Antwort
Where can you get the replacement part? I'm finding it difficult.
Niall Murray - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
Insgesamt: 2,278
