Zum Hauptinhalt wechseln
Motorola Moto X 2nd Generation Rear Camera Replacement
Was du brauchst
    1. Motorola Moto X 2nd Generation Rear Camera Replacement, Rear Camera: Schritt 1, Bild 1 von 3 Motorola Moto X 2nd Generation Rear Camera Replacement, Rear Camera: Schritt 1, Bild 2 von 3 Motorola Moto X 2nd Generation Rear Camera Replacement, Rear Camera: Schritt 1, Bild 3 von 3
      • Remove SIM card tray.
      Frag FixBot
      Kommentar hinzufügen
    2. Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 2, Bild 1 von 2 Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 2, Bild 2 von 2
      • Push the eject pin to open a gap and place a guitar pick into the gap.
      Frag FixBot
    3. Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 3, Bild 1 von 2 Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 3, Bild 2 von 2
      • Slide the guitar pick to cut the adhesive sticker and peel off the back cover.
      Frag FixBot
    4. Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 4, Bild 1 von 2 Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 4, Bild 2 von 2
      • Remove two pieces rubber cover which protecting the flex connectors.
      Frag FixBot
    5. Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 5, Bild 1 von 2 Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 5, Bild 2 von 2
      • Release the power button connecting flex connector and battery connector carefully.
      Frag FixBot
    6. Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 6, Bild 1 von 2 Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 6, Bild 2 von 2
      • Twist off all 18 black torx screws and separate the middle housing from front assembly.
      Frag FixBot
    7. Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 7, Bild 1 von 3 Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 7, Bild 2 von 3 Motorola Moto X 2nd Generation Rear Camera Replacement: Schritt 7, Bild 3 von 3
      • Release rear camera connector and remove it easily.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Sophia
43.911 Reputation
62 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 30
Insgesamt: 1,287
