Zum Hauptinhalt wechseln
Motorola Moto X Back Cover Assembly Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Motorola Moto X Back Cover Assembly Replacement, Back Cover Assembly: Schritt 1, Bild 1 von 3 Motorola Moto X Back Cover Assembly Replacement, Back Cover Assembly: Schritt 1, Bild 2 von 3 Motorola Moto X Back Cover Assembly Replacement, Back Cover Assembly: Schritt 1, Bild 3 von 3
    • In the following steps you will be releasing the clips holding the phone's cases together. However, the back case is also secured with an adhesive pad. After separating the clips you will use an iOpener to allow the case to fully open. Do not attempt to fully open the phone before loosening the adhesive.
    • Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
    • Slide the plastic opening tool along the seam toward the upper corner.
  2. Motorola Moto X Back Cover Assembly Replacement: Schritt 2, Bild 1 von 2 Motorola Moto X Back Cover Assembly Replacement: Schritt 2, Bild 2 von 2
    • Carefully slide the plastic opening tool around the corner, freeing it from clips.
  3. Motorola Moto X Back Cover Assembly Replacement: Schritt 3, Bild 1 von 2 Motorola Moto X Back Cover Assembly Replacement: Schritt 3, Bild 2 von 2
    • Pry around the top right corner of the phone between the two covers.
  4. Motorola Moto X Back Cover Assembly Replacement: Schritt 4, Bild 1 von 3 Motorola Moto X Back Cover Assembly Replacement: Schritt 4, Bild 2 von 3 Motorola Moto X Back Cover Assembly Replacement: Schritt 4, Bild 3 von 3
    • Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
    • The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover.
    • Do not push the opening tool deep into phone, or you may damage internal components.
  5. Motorola Moto X Back Cover Assembly Replacement: Schritt 5, Bild 1 von 1
    • Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
  6. Motorola Moto X Back Cover Assembly Replacement: Schritt 6, Bild 1 von 3 Motorola Moto X Back Cover Assembly Replacement: Schritt 6, Bild 2 von 3 Motorola Moto X Back Cover Assembly Replacement: Schritt 6, Bild 3 von 3
    • Starting from the SIM slot side, carefully peel the back cover off of the phone.
    • The back cover is very flexible, but you don't want to damage any internal components by being too hasty.
    • There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
    • Do not separate the back cover entirely; it is still connected to the phone by the camera flash cable.
    • The flash cable is attached on the power/volume button side of the phone.
  7. Motorola Moto X Back Cover Assembly Replacement: Schritt 7, Bild 1 von 1
    • Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
  8. Motorola Moto X Back Cover Assembly Replacement: Schritt 8, Bild 1 von 3 Motorola Moto X Back Cover Assembly Replacement: Schritt 8, Bild 2 von 3 Motorola Moto X Back Cover Assembly Replacement: Schritt 8, Bild 3 von 3
    • Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector.
    • Be sure to pry only on the flap itself, not on the connector.
    • Pull the flash cable straight out of its socket.
  9. Motorola Moto X Back Cover Assembly Replacement: Schritt 9, Bild 1 von 1
    • Separate the back cover from the phone.
Abschluss
Sam Goldheart
465.762 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 107
