Was du brauchst
Remove the five 3 mm T3 Torx screws from the headphone jack/speaker assembly.
Insert a spudger under the panhandle of the headphone jack/speaker assembly and pry it up from its recess.
Remove the headphone jack/speaker assembly.
Push the tip of a spudger under the microphone assembly clip to free it from the earpiece speaker.
Use the flat end of a spudger to free the microphone assembly cable connector.
Use tweezers to remove the microphone assembly.
Disconnect the front-facing camera cable connector.
Remove the front-facing camera from its recess with a pair of tweezers.
Insert the flat end of a spudger under the motherboard above the button assembly cable, and pry it out of the phone.
Gently lift the motherboard out of the phone, rotating it from the SIM slot edge of the phone.
Use the flat end of a spudger to flip the retaining tab on the display cable ZIF connector.
Carefully pull the display cable out of its connector as you remove the motherboard from the display assembly.
