Zum Hauptinhalt wechseln
Motorola Moto Z2 Play Speaker Replacement
Was du brauchst
  1. Motorola Moto Z2 Play Speaker Replacement, Screen Removal: Schritt 1, Bild 1 von 1
    • Power off your phone before you complete any replacement steps.
  2. Motorola Moto Z2 Play Speaker Replacement: Schritt 2, Bild 1 von 1
    • Heat the edges of your Motorola Moto Z2 Play screen for two to three minutes with a heat gun. You adjust the heat gun to 85 degrees centigrade, and be careful not to hold the heat gun on one position for too long; to avoid damaging, or "hotspotting" the LCD. The screen should be very warm, but not painful, to the touch. Reheat as necessary.
    • If screen is cracked put strong adhesive tape across the screen in order to avoid breaking the screen further and receiving cuts.
    • If you don’t have access to a heat gun, a hair dryer can be used.
  3. Motorola Moto Z2 Play Speaker Replacement: Schritt 3, Bild 1 von 1
    • Place suction cup in the middle of the screen and press down.
  4. Motorola Moto Z2 Play Speaker Replacement: Schritt 4, Bild 1 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 4, Bild 2 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 4, Bild 3 von 3
    • Pry the screen by wedging the plastic opening tool under the screen at the charging port.
    • Work your way around the screen with the plastic opening tool.
    • When you pry near the top-right and bottom-right corners, be careful not to pry too far, or you risk damaging the display cable.
    • Complete these steps carefully because the screen is delicate and can easily crack. If the screen begins to resist prying, reheat the adhesive with your heat gun.
  5. Motorola Moto Z2 Play Speaker Replacement: Schritt 5, Bild 1 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 5, Bild 2 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Use a suction cup to lift up screen from left to right.
    • If you don’t have a suction cup, wedge a spudger or a small plastic card under the screen and lift slowly.
    • Failure to lift screen from left to right can cause damage to interior wires of your phone.
  6. Motorola Moto Z2 Play Speaker Replacement: Schritt 6, Bild 1 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 6, Bild 2 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 6, Bild 3 von 3
    • Identify ribbon connector at the top right of the phone.
    • Pry the black locking bar up gently with a plastic opening tool.
    • Remove the ribbon wires by pulling them out of the connector with a tweezer.
    • The locking bar is the small black bar located on the digitizer’s ZIF connector.
    • Be sure to push the locking bar back down using a spudger after you put the ribbon wire back in since the lock does not lock automatically.
  7. Motorola Moto Z2 Play Speaker Replacement: Schritt 7, Bild 1 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 7, Bild 2 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 7, Bild 3 von 3
    • Identify the ribbon cable, located at the bottom right of the phone.
    • If present, remove kapton (orange) tape covering the cable connector.
    • Flip up the small locking flap on the ZIF connector and use tweezers to slide the cable straight out of its socket.
    • Excessive force is not needed.
  8. Motorola Moto Z2 Play Speaker Replacement: Schritt 8, Bild 1 von 1
    • Lift the screen from the phone to completely detach.
    • If screen doesn't detach, go back to step 7 and 8 to make sure the bar is unlocked and ribbon connector is fully detached.
    • During reassembly, you may need to apply or replace the display adhesive on your display assembly. Use our display adhesive application guide to apply the adhesive and reseal your device.
  9. Motorola Moto Z2 Play Speaker Replacement, Battery: Schritt 9, Bild 1 von 2 Motorola Moto Z2 Play Speaker Replacement, Battery: Schritt 9, Bild 2 von 2
    • Remove the orange tape, located at the bottom right of the phone, using tweezers.
    • Do not discard tape.
  10. Motorola Moto Z2 Play Speaker Replacement: Schritt 10, Bild 1 von 2 Motorola Moto Z2 Play Speaker Replacement: Schritt 10, Bild 2 von 2
    • Detach the red and black battery wire by lifting up with tweezers.
  11. Motorola Moto Z2 Play Speaker Replacement: Schritt 11, Bild 1 von 2 Motorola Moto Z2 Play Speaker Replacement: Schritt 11, Bild 2 von 2
    • Peel back the black tape that is located on the battery.
    • Make sure you pull back gently so you can reuse the tape with reassembly.
  12. Motorola Moto Z2 Play Speaker Replacement: Schritt 12, Bild 1 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 12, Bild 2 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 12, Bild 3 von 3
    • Lift the black tape and slide a card under the battery.
    • Align the card parallel and under the battery.
    • Wedge the card further under the battery.
    • Lift the card up to assist in removing the battery from the adhesive.
  13. Motorola Moto Z2 Play Speaker Replacement: Schritt 13, Bild 1 von 1
    • Lift to remove the battery from the device completely.
  14. Motorola Moto Z2 Play Speaker Replacement, Speaker: Schritt 14, Bild 1 von 1
    • Remove the three silver 2.6 mm T3 Torx screws on the speaker shell at the top of the phone with a screwdriver by turning counterclockwise.
    • Remove the four black 3.5 mm T3 Torx screws on the speaker shell at the top of the phone with a screwdriver by turning counterclockwise.
    • It is helpful to keep screws on a magnetic surface to avoid losing them.
  15. Motorola Moto Z2 Play Speaker Replacement: Schritt 15, Bild 1 von 1
    • Lift up the silver metallic tape using the tweezers.
  16. Motorola Moto Z2 Play Speaker Replacement: Schritt 16, Bild 1 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 16, Bild 2 von 3 Motorola Moto Z2 Play Speaker Replacement: Schritt 16, Bild 3 von 3
    • Lift gently to completely remove speaker housing using tweezers.
    • Try lifting the speaker housing from both sides slightly before removing completely.
  17. Motorola Moto Z2 Play Speaker Replacement: Schritt 17, Bild 1 von 2 Motorola Moto Z2 Play Speaker Replacement: Schritt 17, Bild 2 von 2
    • Place the housing upside down in order to continue working.
    • Pry the speaker from the housing with a plastic opening tool.
    • When reassembling, make sure the metal connectors of speaker are in the bottom left and right corners (correct orientation).
    • Speaker clicks in on reassembly.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team S19-G5, Livingston Winter 2018 Mitglied von Cal Poly, Team S19-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G5
4 Mitglieder
30 Anleitungen geschrieben
1 Kommentar zur Anleitung
Hi,
The guide was very detailed, kudos to that. Recently My phone fell of from my hand into glass of whisky :( hopefully no physical damage and i speedily switched off and dried it off . I tried to find any fault i found that when I am trying to play music through google music, youtube, any app or trying to call i am not able to hear any sound, yet the phone ringtone works, absolutely fine. Bluetooth and headphone jack when used its fine.
first . when i am dialing someone i am not able to hear any sound through normal ear piece, but i am able to hear when sound speaker is put on.
secondly, I am not able to hear any sound while playing videos or music in any app be it any app, chrome, youtube, google music.
Can you suggest me that what can be the issue..?
jacob alexander - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 30
Insgesamt: 2,632
