Was du brauchst
Remove the back cover by sliding the clip and lifting up the bottom of the cover.
Once all four screws are removed, you should be able to pop off the back half of the phone.
Peal the back of the keypad off of the phone. (Highlighted area are the parts where you can begin to peal from). That white pad is what is being replaced.
Take your new key pad and line the holes up with the pegs sticking out of the phone. (Pegs are highlighted).
Secure the rest of the key pad.
Snap the front and back of the phone back together and reinsert screws 1 through 4.
