Einleitung
This guide will focus on disassembling the necessary components for the phone in order to get to the camera hardware and remove it from the motherboard.
Was du brauchst
Turn the phone face down.
Press and hold the release button in the middle of the back panel.
Slide the bottom panel down to remove.
Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
Slide the upper case to the right and lift up.
Lift the camera sticker so that it doesn't get damaged.
Once the screws are removed, use the plastic opening tool to remove the black casing.
Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
