Einleitung
Being able to access the LCD display of your Motorola Q Global is important if you wish to do self-maintenance. Here, we show you how to do so.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Turn the phone face down.
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown. When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Press inwardly on the upper casing to release.
    • Press inwardly on the upper casing to release.
  4. Slide the upper case rightward and lift up.
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  6. Remove the 6 screws using the T5 torx screwdriver. Remove the 6 screws using the T5 torx screwdriver.
    • Remove the 6 screws using the T5 torx screwdriver.
  7. Once the screws are removed, use the plastic opening tool to remove the black casing.
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  8. Remove both screws on the mounted surface with a T5 screwdriver. Remove both screws on the mounted surface with a T5 screwdriver.
    • Remove both screws on the mounted surface with a T5 screwdriver.
  9. Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool. Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  10. Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit. Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit.
    • Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit.
  11. Separate the front plate from the circuit board. The LCD screen is attached to the circuit board by a thin ribbon.
    • Separate the front plate from the circuit board.
    • The LCD screen is attached to the circuit board by a thin ribbon.
    • Switch the lock on top of the circuit entry from horizontal to vertical.
  12. Insert the new LCD screen into the circuit.
    • Insert the new LCD screen into the circuit.
Abschluss
Will Dickman
28 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 6-31, Regan Fall 2012 Mitglied von Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 727
