Einleitung
Being able to access the LCD display of your Motorola Q Global is important if you wish to do self-maintenance. Here, we show you how to do so.
Was du brauchst
Turn the phone face down.
Press and hold the release button in the middle of the back panel.
Slide the bottom panel down to remove.
Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
Slide the upper case rightward and lift up.
Lift the camera sticker so that it does not get damaged.
Once the screws are removed, use the plastic opening tool to remove the black casing.
Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit.
Separate the front plate from the circuit board.
The LCD screen is attached to the circuit board by a thin ribbon.
Switch the lock on top of the circuit entry from horizontal to vertical.
