Einleitung
This guide outlines the steps to disassemble the Q Global to access the internal speakers. It can be used to replace or repair a damaged speaker.
Was du brauchst
Turn the phone face down.
Press and hold the release button in the middle of the back panel.
Slide the bottom panel down to remove.
Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
Slide the upper case rightward and lift up.
Lift the camera sticker so that it does not get damaged.
Once the screws are removed, use the plastic opening tool to remove the black casing.
