Zum Hauptinhalt wechseln
Motorola Q Global Speakers Replacement
Was du brauchst
  1. Motorola Q Global Speakers Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Speakers Replacement: Schritt 2, Bild 1 von 2 Motorola Q Global Speakers Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Speakers Replacement, Speakers: Schritt 3, Bild 1 von 1
    • Press inwardly on the upper casing until it pops out of the phone.
  4. Motorola Q Global Speakers Replacement: Schritt 4, Bild 1 von 1
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Speakers Replacement: Schritt 5, Bild 1 von 2 Motorola Q Global Speakers Replacement: Schritt 5, Bild 2 von 2
    • Remove the six labeled screws with a T5 torx screw driver.
  6. Motorola Q Global Speakers Replacement: Schritt 6, Bild 1 von 1
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Speakers Replacement: Schritt 7, Bild 1 von 1
    • Remove the speakers by using the plastic remover tool.
  8. Motorola Q Global Speakers Replacement: Schritt 8, Bild 1 von 1
    • Insert the new speakers by gently pressing them down into place.
Abschluss
Cal Poly, Team 6-31, Regan Fall 2012 Mitglied von Cal Poly, Team 6-31, Regan Fall 2012
CPSU-REGAN-F12S6G31
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 623
