Einleitung
This guide requires the removal of various parts and screws so make sure you are in a clean and organized environment to prevent the loss of any components.
Was du brauchst
Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
Remove the plastic yellow tape on the battery connector using the spudger.
Pry up on the orange connection to release it from the motherboard.
Using tweezers, remove the clear plastic covering on the speaker.
Pry open the connection by lifting up on the speaker wire connector.
Using the spudger tool, release the yellow ribbon cable on the headphone jack cover by pushing up on the connection.
Remove the cover from the motherboard.
Release the yellow flex cable on the right side of the phone using the spudger by lifting up on the retaining clip.
Wedge the spudger between the motherboard and the back case.
Work your way around the entire edge of the motherboard to release it and remove it from the back of the phone.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
so i have an old XT912 and i thought the other day it would be cool to have it running linux
however the device has a broken power button
actually no power button was too rough with it back in the when i had little knowledge about opening phones
the button is gone lol i remember using using a small screw driver to get it to respond a few times and it just stopped after a while
i think i dug it right off the board do you thinks its worth it to attempt to fix it or is there another way to get it to respond to power
>>>>>>>>>(-_//)
