Zum Hauptinhalt wechseln
Motorola RAZR Maxx HD Rear-Facing Camera Replacement
Was du brauchst
  1. Motorola RAZR Maxx HD Rear-Facing Camera Replacement, Screen Removal: Schritt 1, Bild 1 von 2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement, Screen Removal: Schritt 1, Bild 2 von 2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 2, Bild 1 von 2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 2, Bild 2 von 2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 3, Bild 1 von 2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 3, Bild 2 von 2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 4, Bild 1 von 2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 4, Bild 2 von 2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Rear-Facing Camera Replacement, Rear-Facing Camera: Schritt 5, Bild 1 von 2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement, Rear-Facing Camera: Schritt 5, Bild 2 von 2
    • Using a T5 Torx screwdriver, unscrew the two 4.0mm screws on the rear-facing camera cover.
  6. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 6, Bild 1 von 2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 6, Bild 2 von 2
    • Use tweezers to remove the rear-facing camera cover.
  7. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 7, Bild 1 von 2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 7, Bild 2 von 2
    • Use the spudger to gently lift the rear-facing camera until it is detached from the back cover.
    • Release the yellow ribbon cable by lifting up on the connection to the motherboard with the spudger.
  8. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 8, Bild 1 von 2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: Schritt 8, Bild 2 von 2
    • Use tweezers to gently remove the rear-facing camera by lifting it up off of the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Hristo
150 Reputation
1 Anleitung geschrieben
Cal Poly, Team 8-40, Amido Winter 2015 Mitglied von Cal Poly, Team 8-40, Amido Winter 2015
CPSU-AMIDO-W15S8G40
5 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 387
