Einleitung
Use this repair guide to replace the camera in a Motorola RAZR2 v9m.
Was du brauchst
Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
Flip open the RAZR2 with the keypad and main LCD facing you.
Insert a spudger into the small gap above the plastic screen.
Gently pry the screen away from the phone.
The plastic screen is held in place by adhesive. Run the spudger along both sides of the screen to separate it from the RAZR2.
Lift the screen away from the phone.
Use a plastic opening tool to pry the top end of the metal frame away from the RAZR2.
Insert a plastic opening tool under the metal frame at the hinge of the RAZR2.
Gently pry the hinge portion of the metal frame away from the phone.
Use the plastic opening tool to gently pry the motherboard cable out of its socket.
Use the plastic opening tool to gently pry the camera cable out of its socket.
Use a plastic opening tool to gently pry the camera assembly away from the RAZR2.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
