Zum Hauptinhalt wechseln
Motorola RAZR2 v9m Flip-stop Bumper Pad Replacement
Was du brauchst
  1. Motorola RAZR2 v9m Flip-stop Bumper Pad Replacement, Flip-stop Bumper Pad: Schritt 1, Bild 1 von 3 Motorola RAZR2 v9m Flip-stop Bumper Pad Replacement, Flip-stop Bumper Pad: Schritt 1, Bild 2 von 3 Motorola RAZR2 v9m Flip-stop Bumper Pad Replacement, Flip-stop Bumper Pad: Schritt 1, Bild 3 von 3
    • Gently press the pointy end of the spudger into the edge of the bumper until it bows and separates from the phone.
    • The bumper is held in place with adhesive. If you plan on reusing the bumper, then use clean tools to keep the surface sticky.
    • Grab the bowed portion of bumper. Gently lift and peel the bumper away from the phone.
    • Remember that the bumper will be sticky. Place it somewhere clean if you will be reusing it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 412
