Einleitung
Use this guide to remove and install a keypad in a Motorola RAZR2 v9m. Also works for other RAZR2 v8 and RAZR v9 models.
Was du brauchst
Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
Flip the RAZR2 open with the battery compartment facing you.
Pull the white battery tab away from the phone to reveal a small black gap in the battery compartment.
Place the spudger into this gap. Rest the spudger against the black plastic inside of the gap.
Rest the spudger/scewdriver between the top of the black plastic and the metal body of the phone and leaver the two apart to release the top clip on the keyboard.and the top of the keypad pops out from the RAZR2.
Use a plastic opening tool to gently pry one side of the keypad away from the RAZR2.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
