Einleitung
Use this repair guide to replace an SD card in a Motorola RAZR2 v9m.
Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
Press the exposed portion of the SD card towards the bottom of the phone until you hear a click. The SD card will slide into the phone about 10 mm.
Release the SD card. A spring will push it partially out of the phone.
Grasp the card by the edges and remove.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
