Zum Hauptinhalt wechseln
Motorola Razr V3 Antenna Replacement
Was du brauchst
  1. Motorola Razr V3 Antenna Replacement, Battery: Schritt 1, Bild 1 von 2 Motorola Razr V3 Antenna Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
    Frag FixBot
    Kommentar hinzufügen
  2. Motorola Razr V3 Antenna Replacement: Schritt 2, Bild 1 von 2 Motorola Razr V3 Antenna Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
    Frag FixBot
  3. Motorola Razr V3 Antenna Replacement, Antenna: Schritt 3, Bild 1 von 1
    • Unscrew the two 5mm T6 Torx screws form the phone.
    Frag FixBot
  4. Motorola Razr V3 Antenna Replacement: Schritt 4, Bild 1 von 1
    • Pry open the back of the phone using the spudger. There are four clips, one on the left, one on the right, and two on the bottom of the phone.
    • You can rotate the phone left and right to get easier access while prying.
    • Make sure to fold back of phone down (or left depending on your orientation) after separating from body as there is ribbon connecting the back to the phone's body which can be ripped if pulled the wrong way.
    • The tab as well as the plastic clips are fragile, be careful when using them.
    Frag FixBot
  5. Motorola Razr V3 Antenna Replacement: Schritt 5, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, disconnect the copper ribbon on the left side of the phone by pulling it up from the circuit board.
    • The clear part below the circuit board is the antenna.
    Frag FixBot
  6. Motorola Razr V3 Antenna Replacement: Schritt 6, Bild 1 von 1
    • Remove the antenna by pushing in the tabs on the sides with the spudger, and pulling it out.
    • These clips are also fragile.
    • When reassembling, make sure the copper piece of the antenna is properly inserted between the two copper clips that stick up from the phone.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 3-46, Amido Spring 2013 Mitglied von Cal Poly, Team 3-46, Amido Spring 2013
CPSU-AMIDO-S13S3G46
4 Mitglieder
20 Anleitungen geschrieben
1 Kommentar zur Anleitung
Elok tenan Jan sing posting
Haryanto - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 57
Insgesamt: 4,588
